Energy Storage Partner Program
Get the most from any battery chemistry with Morningstar charge controllers. Use the guides, compatibility information, and partner-tested settings below to set up your system with confidence.
Energy Storage Partner ProgramMorningstar’s Energy Storage Partner™ program (ESP) is an ongoing collaboration with lithium and other advanced chemistry/technology battery brands to create Custom Settings Implementation Guides that confirm and thoroughly document optimal charge controller settings to improve battery health and performance in your systems.
[READ MORE ABOUT THE ESP PROGRAM AND CUSTOM SETTINGS (OPEN LOOP) AND BMS CLOSED LOOP SETUP]
See the chart below to access custom settings guides, configuration files, and information about supported features for your battery brand and Morningstar product. If you are using a lithium iron phosphate battery that is not included in the chart, please consult our Lithium Iron Phosphate Battery Custom Settings document.
Brand Custom Settings Guide
provides recommended absorption, float and other battery settings/info for your battery brand
MSView Custom Settings Configuration Files
MSView battery charging settings files for SunSaver, ProStar, TriStar, GenStar  product families
LiveView Custom Settings Configuration Files
LiveView battery charging settings files for GenStar product families
BMS Closed Loop Setup Guide
Use ReadyBMS Closed Loop Setup without Custom Charge Settings
Deka duration by MK battery Deka Duration Custom Settings Guide Deka Duration MSView Configuration Files Deka Duration LiveView Configuration Files Deka Duration Closed Loop Setup Guide
Battle born batteries Battle Born Custom Settings Guide Battle Born MSView Configuration Files NA NA
blue planet energy Blue Planet Custom Settings Guide Blue Planet MSView Configuration Files NA NA
Discovery Discover Custom Settings Guide Discover MSView Configuration Files NA Discover Closed Loop Setup Guide
Dragonfly energy Dragonfly Custom Settings Guide Dragonfly MSView Configuration Files NA NA
enerdrive Enerdrive Custom Settings Guide Enerdrive MSView Configuration Files NA NA
fortress power logo Fortress Custom Settings Guide Fortress MSView Configuration Files NA NA
gen z genZ Custom Settings Guide genZ MSView Configuration Files NA NA
iron edison Iron Edison Custom Settings Guide Iron Edison MSView Configuration Files NA NA
kilovault logo Kilovault Custom Settings Guide Kilovault MSView Configuration Files NA NA
lithionics battery Lithionics Custom Settings Guide Lithionics MSView Configuration Files NA NA
lithiumwerks logo Lithium Werks Custom Settings Guide Lithium Werks MSView Configuration Files NA NA
MK Battery MK Battery Custom Settings Guide MK Battery MSView Configuration Files NA NA
moura logo Moura Custom
Settings Guide
Moura MSView Configuration Files Moura GenStar LiveView Configuration Files NA
NEC energy logo NEC Energy Custom Settings Guide NEC Energy MSView Configuration Files NA NA
northstar logo NorthStar Custom Settings Guide NorthStar MSView Configuration Files NA NA
Polarium logo Polarium Custom Settings Guide Polarium MSView Configuration Files NA NA
Power logo PowerPlus Custom Settings Guide PowerPlus MSView Configuration Files PowerPlus GenStar LiveView Configuration Files NA
pylontech logo PylonTech Custom Settings Guide PylonTech MSView Configuration Files NA PylonTech Closed Loop Setup Guide
relion logo ReLiON Custom Settings Guide ReLion MSView Configuration Files NA NA
sentry logo Sentry Custom Settings Guide Sentry MSView Configuration Files NA NA
simpliphi power Simpliphi Custom Settings Guide Simpliphi MSView Configuration Files NA NA
trojan battery company Trojan Custom Settings Guide Trojan MSView Configuration Files NA NA
UPG stay powered UPG Custom Settings Guide MK MSView Configuration Files NA NA
WECO WECO Custom Settings Guide WECO MSView Configuration Files WECO LiveView Configuration Files WECO Closed Loop
Setup Guide
