Technical Documents
Real Time Control of Morningstar Products Using Open Protocol MODBUS and MSView Software
System integrators and project engineers often design systems that require external control over one or more Morningstar products during operation. Many Morningstar products include open protocol MODBUS which is well suited to provide external control. This is a simple but powerful software solution. This document provides the information needed to implement external control of Morningstar equipment
Read More
Relay Driver Overview and Applications
Describes Basic and Advanced Settings for common and alternative/novel uses for the Relay driver (RD-1). Morningstar’s Relay Driver (RD-1) is a fully programmable 4-channel logic controller which can be used to control mechanical or solid-state relays in AC and DC power systems. This guide provides an overview of the Relay Driver and includes possible configuration settings and how to apply them to different applications and systems.
Read More
Morningstar Communications Document (Morningstar Product Connectivity Manual - Networking & Communications)
A comprehensive guide to communication with Morningstar products including MeterBus networks, Serial RS-232 and EIA-485 networks, Ethernet, HTTP, web interfaces, related hardware and cables.
Read More
Morningstar Solar Controller System Sizing with 60 Cell Modules
This Tech Tip discusses the use of today’s 60 cell PV modules with Morningstar’s solar controllers. It explains why 60 cell modules are not well adapted for meeting the nominal array voltage requirements of PWM controllers. It also shows how Morningstar’s MPPT controllers can be used with great success at higher input voltages.
Read More
Adjusting Morningstar Data Log File for Your Time Zone
When retrieving Internal Log Data from a controller or creating a Data Log file with the data logging feature of MSView, the data gets saved to a .csv file which can be opened using a spreadsheet software program like Excel. The format of the Date and Time is in ISO 8601 format which is an international convention for exchanging date and time information.
Read More
Mid-Range MPPT Solar Charge Controller Request for Proposal (RFP) Template
This sample template was created to help installers, designers, and engineering, procurement & construction personnel to create an RFP that will attract responses from qualified parties that can meet key mid-range MPPT charge controller specifications to help ensure deployment of a reliable, high quality off-grid system.
Read More
DIP Switch Settings Document
Contains information about DIP Switch settings for TriStar MPPT, ProStar MPPT, SunSaver MPPT, TriStar PWM, and ProStar Gen3 PWM concerning charge control, lighting control, load control, and diversion control where applicable.
Read More
